While looking for the exact syntax of a function, “Insert a function” of the contextual menu is not available from inside a cell, while writing a formula. To get access to this tab of the contextual menu, I need to call it from an empty cell.
By example, I am writing formula starting with =IF( and I do not know the Onlyoffice syntax for the logical negation. I need to stop writing my formula, then select another cell and then right click in order to get the contectual menu with “Insert a function”, then select “Logical” group and choose the proper function. Then I need to copy and paste this latter in the former =IF( function.
Wish : be able to get the “Insert function” from the place where I need it while writing a function, even in the middle of the wrting of this function.
Kind regards
