I am having an issue that NGiNX will stop running for no particular reason this causes Nextcloud to lose connection with Onlyoffice document server.
nginx version: nginx/1.18.0 (Ubuntu)
systemctl status:
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: failed (Result: core-dump) since Thu 2021-11-04 00:00:26 UTC; 12h ago
Docs: man:nginx(8)
Process: 201 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 239 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 341961 ExecReload=/usr/sbin/nginx -g daemon on; master_process on; -s reload (code=exited, status=0/SUCCESS)
Main PID: 265 (code=dumped, signal=SEGV)
Tasks: 0 (limit: 38351)
Memory: 20.8M
CGroup: /system.slice/nginx.service
Nov 04 00:00:26 onlyoffice systemd[1]: nginx.service: Killing process 187951 (nginx) with signal SIGKILL.
Nov 04 00:00:26 onlyoffice systemd[1]: nginx.service: Killing process 187952 (nginx) with signal SIGKILL.
Nov 04 00:00:26 onlyoffice systemd[1]: nginx.service: Killing process 187953 (nginx) with signal SIGKILL.
Nov 04 00:00:26 onlyoffice systemd[1]: nginx.service: Killing process 187927 (nginx) with signal SIGKILL.
Nov 04 00:00:26 onlyoffice systemd[1]: nginx.service: Killing process 187949 (nginx) with signal SIGKILL.
Nov 04 00:00:26 onlyoffice systemd[1]: nginx.service: Killing process 187950 (nginx) with signal SIGKILL.
Nov 04 00:00:26 onlyoffice systemd[1]: nginx.service: Failed with result 'core-dump'.
error.log
2021/11/04 12:28:36 [info] 422964#422964: Using 32768KiB of shared memory for nchan in /etc/nginx/nginx.conf:63
2021/11/03 00:00:06 [emerg] 265#265: chown("/dev/null", 33) failed (1: Operation not permitted)
2021/11/04 00:00:26 [notice] 341961#341961: signal process started
2021/11/01 18:32:21 [info] 26904#26904: Using 32768KiB of shared memory for nchan in /etc/nginx/nginx.conf:63
2021/11/01 18:33:26 [info] 27872#27872: Using 32768KiB of shared memory for nchan in /etc/nginx/nginx.conf:63
2021/11/01 18:43:39 [info] 202#202: Using 32768KiB of shared memory for nchan in /etc/nginx/nginx.conf:63
2021/11/01 18:44:51 [info] 201#201: Using 32768KiB of shared memory for nchan in /etc/nginx/nginx.conf:63
2021/11/03 00:00:05 [notice] 187841#187841: signal process started
Why is this happening? How can I fix this?
