ONLYOFFICE Workspace 12.5: enhanced security, optimized document management, Dark theme, and more
ONLYOFFICE Workspace 12.5 released
Nginx problem of proxy Virtual path
i have nginx for proxy problem.
follow in problem descripton:
i have 3 host vm , designations foo ,bar1,bar2
my network framwork like this:
question : when i try to get the document server script file of api.js
the broswer ask me :
finally ,i want set config nginx Virtual path to connect documentserver that got app.js file
this is my nginx of main host config :
#user  nobody;
worker_processes  1;
#error_log  logs/error.log;
#error_log  logs/error.log  notice;
#error_log  logs/error.log  info;
#pid        logs/nginx.pid;
events {
    worker_connections  1024;
http {
	upstream onlyoffice{
		server 172.17.11.27:80;
	map $http_x_forwarded_proto $the_scheme {
		 default $http_x_forwarded_proto;
		 "" $scheme;
	map $http_x_forwarded_host $the_host {
		default $http_x_forwarded_host;
		"" $host;
	map $http_upgrade $proxy_connection {
	  default upgrade;
	  "" close;
	proxy_set_header Upgrade $http_upgrade;
	proxy_set_header Connection $proxy_connection;
	proxy_set_header X-Forwarded-Host $the_host/documentserver-virtual-path;
	proxy_set_header X-Forwarded-Proto $the_scheme;
	proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    include       mime.types;
    default_type  application/octet-stream;
    client_max_body_size 10240m;
    #log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
    #                  '$status $body_bytes_sent "$http_referer" '
    #                  '"$http_user_agent" "$http_x_forwarded_for"';
    #access_log  logs/access.log  main;
    sendfile        on;
    #tcp_nopush     on;
    #keepalive_timeout  0;
    keepalive_timeout  65;
	 gzip on;
	 gzip_buffers 4 16k;
	gzip_comp_level 5;
	gzip_min_length 100;
	gzip_types text/plain application/javascript text/css application/xml text/javascript application/x-httpd-php image/jpeg image/gif image/png;
    server {
        listen       28080;
        server_name  xxxxxxx;
        charset utf-8;
        access_log  logs/host.access.log  main;
        add_header Access-Control-Allow-Origin '*';
        add_header Access-Control-Allow-Credentials "true";
		add_header Access-Control-Allow-Methods 'GET, POST, OPTIONS';
		add_header Access-Control-Allow-Headers  'token,DNT,X-Mx-ReqToken,Keep-Alive,User-Agent,XRequested-With';
		if ($request_method = 'OPTIONS') {
			return 200;
        location / {
            root   /usr/local/data/nginx/html/dist;
            index  index.html index.htm;
			try_files $uri $uri/ @router;
		location @router {
				rewrite ^.*$ /index.html last;
		location /stage-api/ {   #my application callback server
		 proxy_pass http://172.17.11.24:8080/;
		 proxy_set_header Host $host;
         proxy_set_header Connection "upgrade";
		 proxy_set_header X-Real-IP  $remote_addr;
		 proxy_set_header X-Forwarder-For @proxy_add_x_forwarded_for;
		 proxy_set_header Product_Type 2;
		location /onlyoffice-api/ {
            proxy_pass http://onlyoffice;   # documentserver
		location /dev-api/ {
		location /prod-api/ {
		location /fileonline/ {
			proxy_pass http://172.17.11.24:18080/;
        error_page   500 502 503 504  /50x.html;
        location = /50x.html {
            root   html;
and the documentserver nginx is default config :
Document Server version:7.3
OS:centos 7
Browser version:chorm
Hello @votouch
Do I understand it right from your scheme that there’s nginx proxy server in front of Document server? If so, I believe you have to start your research with proxy examples here: Using ONLYOFFICE Docs behind the proxy - ONLYOFFICE
Also please check out that both sides (your application\storage and Document server) are available for each other. You can do it with curl\wget commands.
So far it looks like network rules issue.
all right , like network rules issue. :joy:
I assume that you might have resolved the situation. If not, please provide us with details.
