Server Version: 7.5.1
When opening txt file it didn’t get rendered. From Chrome devtools/websocket, I saw message complaining needparams
{"type":"documentOpen","data":{"type":"open","status":"needparams","data":"https://mydomain.com/cache/files/data/e9004b03-4e97-46a1-86e4-1af7a2821619.txt/origin.txt/origin.txt?md5=YONvtj4_EuRuLyciJ_xmkg&expires=1715225857&filename=origin.txt"}}
After searching server code the it’s from
canvaservice.js
case commonDefines.FileStatus.NeedParams:
outputData.setStatus('needparams');
which throws by converterservice.js convertByCmd at getConvertStatus.
Is it because the converter didn’t correctly convert .txt to Editor.Bin ?
[2024-05-09T06:01:50.605] [DEBUG] [localhost] [e9004b03-4e97-46a1-86e4-1af7a2821619.txt] [uid-1] nodeJS - error spawnAsync Error: Process exited with non-zero code: 89
at ChildProcess.<anonymous> (/snapshot/server/build/server/FileConverter/node_modules/@expo/spawn-async/build/spawnAsync.js:39:21)
at ChildProcess.emit (events.js:400:28)
at maybeClose (internal/child_process.js:1088:16)
at Process.ChildProcess._handle.onexit (internal/child_process.js:296:5)
[2024-05-09T06:01:50.605] [DEBUG] [localhost] [e9004b03-4e97-46a1-86e4-1af7a2821619.txt] [uid-1] nodeJS - stdout:
[2024-05-09T06:01:50.605] [DEBUG] [localhost] [e9004b03-4e97-46a1-86e4-1af7a2821619.txt] [uid-1] nodeJS - stderr:
[2024-05-09T06:01:50.605] [DEBUG] [localhost] [e9004b03-4e97-46a1-86e4-1af7a2821619.txt] [uid-1] nodeJS - ExitCode (code=89;signal=null;error:-89)
[2024-05-09T06:01:50.611] [DEBUG] [localhost] [e9004b03-4e97-46a1-86e4-1af7a2821619.txt] [uid-1] nodeJS - processUploadToStorage complete
[2024-05-09T06:01:50.612] [DEBUG] [localhost] [e9004b03-4e97-46a1-86e4-1af7a2821619.txt] [uid-1] nodeJS - output (data={"ctx":{"tenant":"localhost","docId":"e9004b03-4e97-46a1-86e4-1af7a2821619.txt","userId":"uid-1"},"cmd":{"withAuthorization":true,"wopiParams":null,"c":"open","id":"e9004b03-4e97-46a1-86e4-1af7a2821619.txt","userid":"uid-1","format":"txt","url":"https://mydomain.com/example/download?fileName=e9004b03-4e97-46a1-86e4-1af7a2821619.txt&useraddress=example.com","title":"Hello.txt","outputformat":8193,"outputpath":"Editor.bin","embeddedfonts":false,"status_info":-89,"nobase64":true,"convertToOrigin":".pdf.xps.oxps.djvu"}})
