More fillable features for PDF like corssmark or checkmark
Do you want to: Suggest a feature
OS version: Windows 11
App version: 8.1.0.169 (x64 exe)
Hi,
Could You consider adding more ways of filling PDF just like “crossmark” or “checkmark” visible on photo bellow:
This feature is very helpful in case You have to choose one checkbox
And there is not really a shape that could replace crossmark (at least in my opinion)
Hello @dedoci
Just to make things clear. Do I understand it right that you need “crossmark” for filling out checkboxes? As far as I can see the checkmark already exists in the editor.
If I misunderstood the desired scenario, please clarify it.
Ok, You’re there is “crossmark” that I didn’t notice but how about this “checkmark”, that’s very useful for to do lists for instance.
Hello @dedoci
In general, you can use Content Controls for that: go to Insert > Content Controls > Checkbox. You can even change symbols that are used as checked and unchecked states of this box in the settings.
