Fedora 39
onlyoffice-desktopeditors-8.0.0-99.el7.x86_64
The test is too small in my decorations,menus, and pop-ups. How do I increase them?
Fedora 39
That did the trick and right under my nose. Thank you! This link (8037) does not work in Firefox
I have Firefox for Ubuntu v123.0 (64-bit). The link opens correctly.
Try opening the link in the browser through âNew Private Windowâ (Ctrl+Shift+P).
Hi Nikolas,
Strangely, Firefox does work in Private Window, but does not work in Safe Mode. And that is a new one on me.
Does this tell you how to fix it?
Thank you!
I have this issue reported over on
I will update them with your work around.
-T
@Nikolas , âInterface scalingâ does not affect the development tool window.
Could it be possible to enable scaling with the keyboard? It seems to be that OnlyOffice is Chrome base, an in Chrome, when you [ctr] + [+]
, or [ctr] + [-]
, the interface scales. This does not happen with OnlyOffice nor itâs development tool.
I have automatically tried ctrl+ a few times, but then look to the bottom right as is typical of Libre Office. So ctr±0 would be welcome. I would keep me from losing track of my train of though while placing âwords on a pageâ
@str
What screen resolution and diagonal size are you using?
I will pass your inquiry to our team!
@Nikolas Iâm using a 3200:1800 (16:9) resolution, no scaling at a GNU/Linux Debian 12.
Administrator: would you pelase change âMicrotestâ to âMicrotextâ (stinkinâ typos)
Are you using X11 or Wayland?
@str
Your suggestion has been added to our implementation queue.Currently, the timelines are uncertain.
