Merge Cells do not match documentation
Fedora 39
OnlyOffice-8.0.1-x86_64.rpm
https://helpcenter.onlyoffice.com/mobile-applications/documents/spreadsheet-editor/editing-cell-properties/merge-cells.aspx
Either the directions are wrong, or the program has a bug, or I am a missing something.
Select two cells or a range of cells and tap the Merge option in the pop-up menu that appears.
What pop up? And right click does not have merge in it either (or I am blind).
MergeCells.mkv (1.1 MB)
The guide you are referring to is the guide for Onlyoffice Documents mobile app, for ONLYOFFICE Desktop Editor and ONLYOFFICE Docs merging please see this guide: Merge cells - ONLYOFFICE
Wrong directions: mumble, mumble. Thank you for the help!
