Menu for commonly used templates
It’d be really nice to have the ability to automatically choose, e.g. the MLA template when creating my document, instead of having to download and choose it manually on the filesystem (in my case, I actually deleted my MLA template because I left it in my Downloads folder). It’s interesting that very few other softwares do it (not even just FOSS, Apple’s Pages excludes this for some reason)
Hello @IoI_xD
Which solution are you using? It is Desktop Editors or Document Server? I am trying to understand whole usage scenario, but it is not quite clear which product is used and in which environment.
I am using Desktop Editors; I am using this for college.
What is the system of your device? I believe the solution is quite easy - you can add your custom templates as DOTX format to Desktop Editors and access them via main menu > Templates tab. Is that what you are looking for?
