I’d prefer to use yyyy-mm-dd as short date format independently of regional settings. It looks like no such feature now.
Hello @SergeiStPete
It is possible to change date format for the cells by opening Number Format menu with combination CTRL+1 and selecting needed format in the drop-down list:
Thank you, but that’s not suitable. So, it looks like the answer is NO, we can’t change default date format.
You are looking for possibility to set a specific date format that will be used whenever you insert date, e.g. with combination Ctrl+;, despite of the format predefined by Regional Settings, is that correct?
Yes, like this. Bit more concrete I’d like to have yyyy-mm-dd as default date format independently of default one for the Regional settings used at this very moment.
Hello @SergeiStPete
If you don’t mind, I will join to this thread too.
We are discussing your request internally, and we will update this thread when we have something to share.
Hi @Alexandre ,
Sorry, was off for a while. That will be great if you update settings, in any case please inform about your decision.
Hello @SergeiStPete
We have finished internal discussion and we are agree that such feature is necessary. We have started working on it.
Thank you for your suggestion! We will update this thread when we have something to share.
sorry for bumping this a year later, but is this still being worked on? same boat as sergei where i’d like to use a universal date format of yyyy-mm-dd
Hello @healcaster
Unfortunately, there is no news on this enhancement.
