Since i was desperatly trying to get MM plugin to work behind nginx. I gave up. an installed OnlyOffice on an separate Server.
This was more or less flawless.
ist is reacheabl and ssl:
https;//d.domain.net
MM Plugin installs normaly and configuring is normal.
But when I try to open any text file i get an internal error.
this is my mattermost log anonymized:
info […] Installing extracted plugin caller=“app/plugin_install.go:429” plugin_id= version=1.2.0
info […] Persisting plugin to filestore caller=“app/plugin_install.go:230” plugin_id=
warn […] No signature when persisting plugin to filestore caller=“app/plugin_install.go:233” plugin_id=
warn […] Unrecognized config permissions tag value. caller=“api4/config.go:448” path=/api/v4/config/patch request_id= ip_addr= user_id= method=PUT tag_value=“sysconsole_write_read"
warn […] Unrecognized config permissions tag value. caller=“api4/config.go:448” path=/api/v4/config/patch request_id= ip_addr= user_id= method=PUT tag_value="sysconsole_writeread"
error […] RPC call to OnActivate plugin failed. caller=“plugin/client_rpc.go:272” plugin_id= error=“unexpected EOF”
error […] plugin process exited caller=“plugin/hclog_adapter.go:79” plugin_id= wrapped_extras=“… exit status 2”
error […] RPC call OnConfigurationChange to plugin failed. caller=“plugin/client_rpc_generated.go:68” plugin_id= error=“connection is shut down”
warn […] Health check failed for plugin caller=“plugin/health_check.go:59” id= error=“plugin RPC connection is not responding”
warn […] error closing client during Kill caller=“plugin/hclog_adapter.go:70” plugin_id= wrapped_extras=“errconnection is shut down”
warn […] plugin failed to exit gracefully caller=“plugin/hclog_adapter.go:72” plugin_id=
warn […] Unrecognized config permissions tag value. caller=“api4/config.go:448” path=/api/v4/config/patch request_id= ip_addr= user_id= method=PUT tag_value="sysconsole_write_read”
error […] Plugin failed to ServeHTTP, RPC call failed caller=“plugin/client_rpc.go:456” plugin_id= error=“connection is shut down”
error […] Plugin failed to ServeHTTP, muxBroker couldn’t accept connection caller=“plugin/client_rpc.go:411” plugin_id= serve_http_stream_id=3 error=“timeout waiting for accept”
error […] Plugin failed to ServeHTTP, muxBroker couldn’t Accept request body connection caller=“plugin/client_rpc.go:430” plugin_id= error=“timeout waiting for accept”
And now? MM 10.9 Professional Ed. Plugin latest version
