Material You Themed Icon
ONLYOFFICE Mobile: Documents
Do you want to: Suggest a feature
Device: Motorola Edge 40 Neo
OS version: Androd 14
App version: 8.3.2
Mode: On Device
I was wondering if there is a possibility that you could update your app icon to support Material You Themed Icons on Android?
I understand that you likely have more serious issues, perhaps this could be implemented in the meantime.
Best regards,
dedoci
Hello @dedoci
We are processing your suggestion, please await my feedback.
I was informed that this suggestion has been registered for further development. Sadly I cannot provide any timelines as of now, but I will keep you posted.
Ok, that’s fine. Thank You so much for your effort.
Hello @dedoci
I’d like to inform you that we are in the process of releasing new version of Documents mobile app. This version beings the suggestion discussed in this topic, please update the app and check the situation again.
The update will be available shortly.
