Margins in OnlyOffice
Do you want to: Suggest a feature
OS version: Windows 11
App version: 8.2.0.143 (x64 exe)
Hi,
Could You tell why suddenly in OnlyOffice 8.2 there is no default MS Word size margins? At least in Poland the standard is 2.54 cm (same for top, bottom, right and left) and litteraly every program that I tested (on my Windows PC with Poland as region) use it. In previous versions there was something called Default US, but now it’s removed. Do you really expect users to create always use custom margins or playing with this quirky solutions with defults that resets with every update?
Hello @rigi
2,54 cm or 1 inch is the default margin for English (United States) so it is indeed wide spread. If you set up your user interface in settings of Desktop Editors to English United States, then you will get these margins. For other countries documents have their own default margins.
In general, if you configure custom margin for your interface language, it will be stored and accessible across all documents and interface languages.
