Mail search filter not working
Report a bug
Community Server/Control Panel version:12.0.1.1748/3.1.1.467
Type of installation of Workspace (docker, deb/rpm, exe)
OS: ubuntu docker installation
after update community server from control panel mail search filter not working anymore… display not meesages
Hello @pabarrientos
Does the search feature work correctly in other modules? I mean Documents, CRM, etc.?
Also go to Community server container > run service onlyofficeIndex status
Go to Elasticsearch container and run systemctl status elasticsearch.
If it’s necessary, restart both services.
NB! We recommend to prepare whole server backup before any server side actions.
onlyofficeIndex status running
elasticsearch systemctl: command not found
restart both service no solution
i found solution updating elesticsearch with script:
sudo bash workspace-install.sh -u true -ics false -ids false -ims false -icp false -skipvc true
then restart both service… solved… thanks for you reply!!
