Mail Module - Multi Email Select
If it’s already a part of Workspaces and I just don’t know the correct key to hold down or something, then my apologies but is it possible to select a range of emails at once from the Mail module?
I know I can click the checkbox next to each email individually, but can I select one and then select another further down the list, and have the selection include all emails between the first and second selected email?
You can do this in nearly every other email client on the market. Usually just by holding Shift or Control while you make the 2nd selection. I haven’t found a way to do it in Workspaces Mail.
Anyone have any idea if this is possible?
Hello @austin3410
Unfortunately, there is no way to select part of the messages in Mail module. An enhancement to implement it was registered earlier, I am forwarding your query for it. Sadly, there is no ETA on it at the moment.
Sorry for the inconvenience.
