ONLYOFFICE cloud: Free / Business / Personal
Do you want to: Report a bug / Ask a how-to question
Browser version: several browsers with different OS.
Any idea why mail merge would stop working? We have a DOCX file which has mail merge fields configured. We upload a CSV or XLSX file to merge those fields. It usually works. Now it’s not working anymore. Same fields, same flow.
Thanks.
Hello @consultactiva
Please describe situation with details. If it’s possible, please reproduce the issue and make a videofile. Also please provide us with test files, so we are able to reproduce the situation on our side.
Hi @Alexandre,
The document doesn’t recognize the fields, but it used to a few days ago. We haven’t changed anything.
It actually prints the PDF of the whole 13 spreadsheet records, but none of the merge fields is printed.
A video of it: 1ContratoFormacaoModelo.docx - ONLYOFFICE
A link to the document with the merge fields: 1ContratoFormacaoModelo.docx - ONLYOFFICE
A link to a testing spreadsheet with nonsense data but the exact same structure: https://consultactiva2.onlyoffice.eu/Products/Files/DocEditor.aspx?fileid=8136121&doc=dEJPZmJ4SnZsblMrQ1lQQ21SWitiaXBicVJCcnB0RER5U1hKTVI1QzhOWT0_IjgxMzYxMjEi0
Thanks.
I posted earlier today on this issue. My results may be different than yours - a mailmerge works, but only once. Subsequent attempts to merge result in the mergefields not being populated. However, if I add another mergefield to the same document, that field will get populated - but only once. When the document is loaded again, the added field does not populate.
Regards,
burque505
Ok, let move discussion to this topic.
Hi. @Alexandre sorry for not responding earlier, I missed the notifications. I’m attaching the two files you can’t access. Document with merge fields and Spreadsheet with merge fields records.
Thanks.
Thank you for provided files, we are checking the situation.
Thank you for provided data. We found a match with known bug (internal number - 59709). We are working on it already.
We will notify you when we have something to share. Thank you for valuable data!
