Macros Plugin install fail?
Onlyoffice Version installed: 8.3.1
OS: MacOS 14.7.4 (Sonoma)
Reproduction steps:
  1. Open Onlyoffice
  2. Create a new spreadsheet
  3. Plugins>Plug in manager>Macros>Install
  4. “Install” button becomes “Remove” but no macros button is added to the plug in tab.
  5. Close Plug in manager
  6. Open plug in manager and search for macros and the button now says install again.
I can add that I was able to install/uninstall other plugins. I tested with “OnlyDraw” and it worked fine.
Hello @Simon1
Macro can be found on view tab… I guess it is fully integrated and doesn’t need to be installed as plugin…
We may ask an update for this page Getting started | ONLYOFFICE as the picture on the dark mode page there is misleading people.
Ah, thank you Yassine.
I somehow stumbled on this blog post and from the screnshots I draw the conclusion macros was a plug in.
