Hi all,
I’m wondering if it’s possible to use accelerator keys in OnlyOffice in MacOS and use Option instead of Alt? I did see in the advanced settings there’s the “Use option key to navigate the user interface using the keyboard” but this doesn’t seem to do anything.
Any help or advice is appreciated.
Thanks!
Hello @martyn
Please provide version of Desktop Editors and version of MacOS so we can review this issue.
Hi Constantine,
Thank you for your response.
Apple Silicon - Version 7.4.0 (539) and MacOS 13.4
Looking forward to hearing back from you.
Thank you for the info.
We will check the situation and I’ll let you know the results.
I have to inform you we have registered this behavior with Options key on MacOS does not activate Navigation with keys mode in our internal system as a bug.
We are working on it already. Thank you for reporting this issue.
Thank you. I will await an update.
Hello again @martyn
We have released new version of Desktop Editor where Use option key to navigate the user interface using the keyboard feature works correctly when pressing Option key.
Please update your app and provide feedback.
