hello
I’ve come across this bug also in linux mint 22.1
Is there any update on a fix?
hello
Hello @steveyh25
We are still working on it. I will update this thread once we have something to share.
We have similar issue on CentOS 7 derivative (RED OS 7) with Only office newer than 7.1.1.57 (on 7.1.1.57 it works fine).
When you try to print in Lanscape orientation. You receive Lanscape oriented content but cut at Portrait size width with empty space left and right.
To solve the problem you should set Landscape (desired) orientation in OnlyOffice, then press Print button. System printing dialog will pop up. Select Portrait orientation. In this case correct Lanscape page will be printed.
Another workaround is to use Quick print function (Ctrl+Shift+P) without printing dialog.
Dear @Corvex
We are still working on the bug mentioned in this thread. We will notify you once the fix is released.
