Linux and Google drive
Hello everyone,
in Android and Windows you can connect onlyoffice to Google drive. This option does not exist in Linux.
Why is that?
Best regards
René
Hi @renegate98 :handshake:
For Windows and MacOS, Google Drive has a file synchronization application that allows you to work with OOXML format files using our editor without additional connections.
Hi @Nikolas ,
thx for your answer. I think, I will try kDrive. In future I want to leave Google. I recently closed my Microsoft account. This becomes more difficult with Google, simply because of the smartphone and its apps.
Anyway, thanks again. Basically the problem has been solved.
Have a nice evening.
René
