problem:LDAP Sync
Community Server/Control Panel version: 11.6.0.1620/3.0.3.410
Type of installation of Workspace (docker, deb/rpm, exe) :docker
OS:centos7
The LDAP sync time is UTC cannot be synchronized using local UTC+8
problem:LDAP Sync
OS:centos7
Hello @igssoft
According to client database you have the commercial license. I think it’s better to contact us via Zendesk to get prompt replies.
My colleagues will need full information about the situation: step-by-step issue scenario and error mesage, what LDAP server you are using.
