In the documentation it is said that, F12 will “edit the active cell and position the insertion point at the end of the cell contents. If editing in a cell is turned off, the insertion point will be moved into the Formula Bar.” My question is, how can you turn off editing in a cell. I can’t find this setting anywhere in the general or advanced settings.
Also, is there a keyboard shortcut for navigating back and forth through tabs/documents when in tabbed mode?
Thank you!
OS version: Arch linux
App version: 7.0.0.127
Downloaded from: AUR
