Thanks, I missed that shortcut.
Do the keyboard shortcuts in that listing require a particular Mac OS?
I am finding that many of them don’t appear to work.
I also don’t understand the use of the Option key as it’s discussed in the Desktop Editors ‘user manual’. Does it refer to pressing the Option key alone or in combination with other keys? Nothing happens when I press it on an OnlyOffice document page or in any of the toolbars, etc.
Do you mean usage of Option to highlight navigation items, i.e. the ones in yellow boxes? If so, the way it works is that after pressing Option you are entering keyboard navigation and to proceed to a specific item you just need to press a key that is referenced in the yellow box next to the necessary item. Here is a demo:
It just an option for easier navigation, this mode cannot be used as a regular shortcuts.
