Jumping to a Comment in PDF Editor
Hi…is there a way to jump to a comment in the PDF editor under MacOS and OnlyOffice 7.5?
If I add comments to various parts of a PDF document, then open the comments sidebar, I can see all the comments I have added. However, when I click on one it does not jump to that comment. The comment window opens at the bottom of the screen, not over the actual comment itself.
Thanks.
Hello @StevieW
I’d like to inform you that this behavior is a bug and it will be fixed in the upcoming hotfix version 7.5.1.
Yes, just got 7.5.1 and it is fixed. Many thanks.
