ONLYOFFICE Mobile: Documents / Projects / Web Editors
Device: Pixelbook Go (Chromebook)
OS version: 104.0.5112.83
App version:
Mode: Connect to Cloud / On Device On Device
Browser version (for Web editors):
What is keyboard shortcut to jump to end of long document?
Dear Wayne,
If you are used to Windows keyboards, you may notice that the Chromebook keyboard is missing some keys. You can fix this by using Alt (or Search) + Up for Page Up , and Alt (or Search) + Down for Page Down . To use Home and End to go to the top and bottom of the page, use Ctrl + Alt + Up and Ctrl + Alt + Down respectively.
Best wishes
Diana
Thank you again. But those solutions don’t work for me. I also have a Page Unresponsive problem with my Chromebook. I have tried different software, but I can’t seem to do documents. With Google Docs I can jump to the end of the document, but there are other issues. I guess I am going to have to do documents on my Windows machine which seems to work consistently well. However, it is not as convenient for me.
