Issue with Auto-Correction in ONLYOFFICE
I am experiencing an issue with the auto-correction feature in the document editor. The automatic text correction disappears while using the program and only reactivates after closing and reopening it.
How can I resolve this issue?
Thank you!
Hello @Redrum79
Please share more details:
  • OS type and version;
  • which product is used exactly (category FORMS does not depict it);
  • version of the product;
  • a video demo with issue.
Salve. Grazie per la risposta .
dunque rispondendo ai punti che mi avete inviato :
    • Linux Mint 21.3 Cinnamon
    • La correzione non funziona nel modulo “Document”
    • ONLYOFFICE versione 8.3.1.25 (deb)
    • Scrivo un documento (foto 1) , non segna gli errori , salvo , chiudo e alla riapertura trovo segnati gli errori (foto 2)
I am sorry, but the official languages of this forum are English and Chinese. If you intend to continue communication, please use of the languages.
As I can see, you are using outdated version. Please update the app and check the situation again.
Sorry for the language used. I tried to better understand the problem and noticed that at the bottom right, the language is set to Italian when the program opens, but then it gets deactivated as soon as I start typing.
P.S . I installed version versione 8.3.2.19 (deb), but the problem persists.
On your screenshot the text language gets hidden, but not the auto-correction. Taking into consideration documentation about spell-checking in document editor, please try selecting a text passage and setting up necessary text language manually and see if after that the issue reproduces.
If your document in written in a single language, you can also test as follows:
  1. Select whole document content with CTRL+A;
  2. Set necessary text language (drop down menu with languages) and document language (globe icon);
  3. Try typing text in the language that was set up.
You can also create a copy of your document specifically for test, if you do not want to change anything in the document.
thanks ,
I unchecked “automatic language detection” and the problem didn’t occur anymore.
I am glad to know that you managed to find the solution. Should I close the topic as solved?
