I am trying to upgrade to Only Office 8.3 version and have done the required changes for that.
Now when i am trying to open the same document which we were able to open in the older version i am getting “Download Failed” and after clicking on “OK” still its not allowing me to do anything in the document.
Previously it was working fine but now i am facing this issue.
Reason to move to New version :- trying to check RTL functionality .
Providing all the logs below ::
Converter Logs :-
[2025-03-04T18:03:33.255] [WARN] [localhost] [docId] [userId] nodeJS - num of CPUs: 8; availableParallelism: undefined
[2025-03-04T18:03:33.274] [WARN] [localhost] [docId] [userId] nodeJS - update cluster with 8 workers
[2025-03-04T18:03:33.494] [WARN] [localhost] [docId] [userId] nodeJS - worker 17056 started.
[2025-03-04T18:03:33.726] [WARN] [localhost] [docId] [userId] nodeJS - worker 24104 started.
[2025-03-04T18:03:34.003] [WARN] [localhost] [docId] [userId] nodeJS - worker 24496 started.
[2025-03-04T18:03:34.282] [WARN] [localhost] [docId] [userId] nodeJS - worker 24516 started.
[2025-03-04T18:03:34.612] [WARN] [localhost] [docId] [userId] nodeJS - worker 28476 started.
[2025-03-04T18:03:35.010] [WARN] [localhost] [docId] [userId] nodeJS - worker 24764 started.
[2025-03-04T18:03:35.430] [WARN] [localhost] [docId] [userId] nodeJS - worker 23572 started.
[2025-03-04T18:03:35.856] [WARN] [localhost] [docId] [userId] nodeJS - worker 26704 started.
Proxy.wrraper Logs :-
2025-03-04T18:03:26.132 INFO service - Stopping DsProxySvc
2025-03-04T18:03:26.399 INFO service - Started process nginx (22968).
2025-03-04T18:03:26.400 DEBUG service - WaitForProcessToExit 24956+22968
2025-03-04T18:03:27.156 INFO service - Finished DsProxySvc
2025-03-04T18:03:27.159 INFO service - Service stopped successfully.
2025-03-04T18:03:44.290 DEBUG console - Starting WinSW in service mode.
2025-03-04T18:03:44.339 INFO service - Starting “C:\Program Files\ONLYOFFICE\DocumentServer\winsw..\nginx\nginx.exe”
2025-03-04T18:03:44.638 INFO service - Started process nginx (8512).
2025-03-04T18:03:44.680 INFO service - Service started successfully.
Example.Wrraper Logs :-
2025-03-04T18:03:22.031 INFO service - Stopping DsExampleSvc
2025-03-04T18:03:22.043 DEBUG service - ProcessKill 17664
2025-03-04T18:03:22.098 INFO service - Child process ‘example (17664)’ canceled with code -1073741510.
2025-03-04T18:03:22.124 INFO service - Finished DsExampleSvc
2025-03-04T18:03:22.126 INFO service - Service stopped successfully.
2025-03-04T18:03:40.955 DEBUG console - Starting WinSW in service mode.
2025-03-04T18:03:41.013 INFO service - Starting “C:\Program Files\ONLYOFFICE\DocumentServer\winsw..\example\example.exe”
2025-03-04T18:03:41.372 INFO service - Started process example (18356).
2025-03-04T18:03:41.418 INFO service - Service started successfully.
DocService Logs :-
[2025-03-04T18:03:39.675] [WARN] [localhost] [docId] [userId] nodeJS - Express server starting…
[2025-03-04T18:03:39.677] [WARN] [localhost] [docId] [userId] nodeJS - Set services.CoAuthoring.token.enable.browser, services.CoAuthoring.token.enable.request.inbox, services.CoAuthoring.token.enable.request.outbox in the Document Server config to prevent an unauthorized access to your documents and the substitution of important parameters in Document Server requests.
[2025-03-04T18:03:40.271] [WARN] [localhost] [docId] [userId] nodeJS - Express server listening on port 8000 in production-windows mode. Version: 8.3.1. Build: 25
