Is it possible to sync sent and received emails older than 1 month (IMAP/SMTP)
Hi,
I’ve just got onlyoffice workspace up and running and I’ve set up my emails by connecting to my existing mail server.
The problem is it’s only giving me about a month’s worth of previous sent and received emails and I need to access some information from 2 or 3 months ago, is there some setting to increase the amount of emails OnlyOffice downloads form my mail server?
Alternatively, is there some command I can run via SSH to have the onlyofficeMailAggregator service or something like that download the older emails as a one-off so that I have access to them?
Failing all that Is there perhaps a way I could manually import them into my inbox and sent folder?
Community server version: 12.5.2.1848
Control panel version: 3.5.0.516
Type of installation of Workspace: docker
OS: Debian 12
hey @timbell :handshake:
You just need to uncheck the box when connecting the email account
I figured it out, it’s this checkbox in the account settings:
Basically, 2 settings - download 30 days worth of emails or download all the emails.
It seemed to take just about all day to download them all but that’s quite understandable, I had better check to see if my server instance needs more disk space allocated to it now.
Ah, I think we posted that at about the same time, thanks very much anyway!
