Is it possible to create a sidebar to display a list of all sheets, similar to LibreOffice Calc?
Do you want to: Create a plugin that would show a sidebar to display all sheets (like in LibreOffice Calc)
Hey @Legionum :wave:
Thank you for your question!
Do you want to create a plugin that displays a sidebar listing all sheets?
Should the plugin only display the list of sheets, or would you like it to allow navigation to a specific sheet when clicking on its name in the list?
Yes. We need a sidebar with a list of all sheets. In this case, it should be possible to go to a specific sheet (for example, by double-clicking on the name of the corresponding sheet)
Hey @Legionum
Thank you for your inquiry and for sharing your detailed suggestion!
Unfortunately, a solution for this didn’t come to mind immediately. I’ll take some time to check the possibilities of implementing this feature using a plugin and will get back to you with more information as soon as I can.
@Legionum
I’ve checked with the team regarding your request. In general, there shouldn’t be any issues with implementing such a plugin.
To achieve this, I can recommend the following methods from the API:
