Is it possible to alter project start date
I have a long running project plan that started in 2022.
Ive removed all the old tasks/dependencies and would like to set the project start date to 1/1/2025
Is this possible?
Otherwise the left hand side of the project Gant is now empty
If not, can I CLONE a project and set a NEW start date?
Latest DOCs release
Thanks
Ivan
Hello @ivan
To be honest, I’m a little bit confused. Do you mean ‘Projects’ module in the Workspace installation?
If so, could you please provide more details about what exactly you’re trying to achieve? Please make screenshots or record a videofile.
Hi Alexandre. I’d like to reset the start date to 1/1/2025
Right now I can scroll left to project inception at 1 July 2022 :slight_smile:
Does that make sense?
Thanks
Ivan
Understood, we are checking the situation. I will contact you shortly.
Hello @ivan
Please clarify if you’re trying to change start date for ‘Tasks’ or ‘Projects’. If it’s Tasks, you should be able to change start date. Could you please record a video file with your actions?
Additionally, please clarify version of your Workspace portal. Is it self-hosted or cloud solution?
many thanks, Ivan
Hello @ivan
Do I understand it right that the situation has been resolved?
Not resolved Alexandre
All the old tasks (pre 2024) are deleted…
Can I upload video in private?
Thanks
Ivan
Yes, please. You can contact me via PM.
Its self hosted Alexandre.
SILLY Q… how do I contact you PM?
thanks
Ivan
I’ve sent you a message in PM.
Ill get the video prepped Saturday Alexandre, thanks for patience.
Ok, please keep us posted.
Hi Alexandre, was laid off, lookig for new job. Will get back to you ASAP.
Hello @ivan
