Do you want to: Is it possible to add custom button to the editor with plugin?
For feature suggestions, describe the result you would like to achieve in detail:
For bug reports, provide the steps to reproduce and if possible a minimal demo of the problem:Is it possible to add custom button to the editor with plugin or any other way?
the button should operate multiple documents opened.
Document Server version:latest
Installation method: docker
OS:windows11
Browser version: 118
Hi,
almost the same, we want to operate multiple .docx file at the same time
the difference is the button shouldn’t be on the ribbon, because it’s for batch operation for multiple operations.
Hi,
@Nikolas , almost 1 year past for #5526, Is there any update?
@softboy99
This is partially implemented, starting from version 8.0.
Running plugins are displayed in the left panel.
Also, you can take a look at how the ChatGPT plugin is implemented.
Hi,
@Nikolas , Is it suitable for the purpose of batch operation of multiple .docx document? I think it’s not for the button location.
Hi @softboy99
Could you please provide a more detailed description of your proposed workflow?
I’m afraid I don’t fully understand your idea yet.
Hi,
eg, when i click one button, we need to put an image to the multiple opened docx for sign the documents
@softboy99
Using a macro or plugin always involves working with one (active) document.
Hi @Nikolas
So, is there any proposal or idea for this scenario?
@softboy99
Do you want to implement working with two documents through this API?
Hi, @Nikolas , sorry for the delay response. The above link is only for how to open mutiple docuemnts at the same time. However there is no api to adding custom button to batch operate the multiple documents. Also no documentation to tell us where to add, Is it possible to add custom button as following?
Hi @softboy99
Thank you for your patience. Unfortunately, there is currently no API or documentation available for adding a custom button to batch operate on multiple documents.
Could you provide examples or references to similar features implemented in other editors? This would help us better understand your use case and explore potential solutions.
hi,
i’m not sure, but i think we need this feature, could you please add it in the future version?
Hello @softboy99
As @Nikolas asks, it’d be nice to have some reference point for your suggestion. Feel free to share anything you find that might be useful for this case.
