ONLYOFFICE Workspace 12.5: enhanced security, optimized document management, Dark theme, and more
ONLYOFFICE Workspace 12.5 released
iPadOS Bug with Documents and Cmd + Arrow Down
ONLYOFFICE Mobile: Documents / Projects / Web Editors
Do you want to: Report a bug / Ask a how-to question
Device: Apple iPad Pro
OS version: iPadOS 16.3.1
App version: 7.2
Mode: Connect to Cloud / On Device (Both on device and multiple cloud connections)
Browser version (for Web editors):N/A
I am giving the OnlyOffice app a try after realizing that I cannot use the document server through nextcloud on a mobile device without an enterprise subscription. A common shortcut on the ipad is CMD+ Down Arrow to jump to the end of a document. When this combo is used in OnlyOffice Documents it results in unexpected behavior. You can type but cannot use the space bar as it does not add spaces. This is both with an attached keyboard as well as the on screen keyboard.
Using the enter key creates new pages in the document while this bug is happening. You can select previously entered text and hit space or enter and it changes the format but does not move the line down or add spaces as expected.
I do not see any other keybind or gui method to change to a specific page or jump to the end of the document. Am I missing something?
Hello @Nappa231
We are checking the situation.
I will update the thread once I get any news.
Thank you for the update. I appreciate you.
Hello again @Nappa231
We have created bug report number 61627 based on this case.
Thank you for reporting this issue. Our team is already working on it.
Please accept our apologies for the inconvenience caused.
