ONLYOFFICE Workspace 12.5: enhanced security, optimized document management, Dark theme, and more
ONLYOFFICE Workspace 12.5 released
Invalid parameter in method about AddContentControl (Other) control
Below is I use the incoming parameters in AddContentControlDatePicker way.
>  controlCommon = "AddContentControlDatePicker";
        prCommon.controlPara[0].Date = prCommon.controlPara[0].DateStr
          ? new Date(prCommon.controlPara[0].DateStr)
          : new Date()
          prCommon.controlPara[0].DateFormat = "YYYY-MMM-DD"
         commonPr = prCommon.controlPara;
      window.Asc.plugin.executeMethod(controlCommon, commonPr);
First, when I pass the DateFormat parameter, the corresponding control configuration has not played a relative thought.
Ii. If I want to modify the corresponding time language configuration, it seems that the corresponding parameters are not provided. Could you please provide them normally?
Also when I was in AddContentControlCheckBox using this method, corresponding to the selected parameters like. I think I have written the parameters correctly. If possible, I hope you can solve this problem as soon as possible.
Hello @bashfuldeng
Please clarify your request. Do I understand it right that you want to use “YYYY-MMM-DD” date format instead of “DD\ MMMM\ YYYY” in this scenario?
If I misunderstood the situation please clarify it.
I think you may have misunderstood me. I mean that no matter what time format I send, it is wrong, including the time format on your official website.
It’s not that I want to use a parameter format. The corresponding parameter of this api is invalid. It’s that the DateFormat parameter is invalid and has no effect
We are checking the situation, I will update this post when we have something to share.
Hello @bashfuldeng
Please provide us with additional information:
  1. Which API exactly do you use in mentioned scenario (where you’ve faced the issue)?
    ONLYOFFICE Api Documentation - Structure of a text document
    ONLYOFFICE Api Documentation - Coding plugin
    ONLYOFFICE Api Documentation - Config
  2. Please provide us with an example of the code where the issue is reproducible.
