Interface Suggestion: Adding Right Sidebar Items To Context Menus
It would be helpful to have some items in the relevant context menus in addition to the Right Sidebar menu. Some examples:
  • Shape fill, borders: Various options are available in the Right Sidebar (Shape settings). Those could also be added into the context menu (e.g. right click shape > Shape advance settings)
  • Text Box: Same as above (right click text box > Shape advance settings)
  • Table: Columns can be adjusted by the context menu ( right click > Table advanced settings > Table tab > Table size). However, row size is not available in that menu. Row size must be adjusted through the Right Sidebar, Table settings.
Forgot to add a link to the Document Editor interface description: Introducing the user interface of the Document Editor
Hello @sporto, thank you for your proposal, we are currently analysing it
Please specify what particular items you would like to be added to the right panel properties menu.
We cannot add all existing options for all objects, as the menu would become endless. Also, it is not possible to add items that require data input, etc.
Hi @DmitriiV, Basically, it would be replicating the right sidebar option in the “advanced settings” popup accessed through the right click context menu. So, really I misspoke and it would not be adding the options to the context menu - it would be to add them to the popup setting accessed clicking Shape/Text Box/Table “advanced settings” in the context menu.
I think this can be best demonstrated with some screenshots (using Shape advanced settings as the example):
  1. Right click > Select Shape advanced settings
  2. Shape - advanced settings popup opens (note that the items in the right sidebar menu are not available in the popup, it would be nice if they could also be accessed in the popup)
Understood, thank you for the clarification. I’ll post here as soon as I have news on the issue
@sporto
Hello, we have registered the relevant new functionality suggestion in our tracking system, I’ll post here as soon as it is implemented on one of the future versions
