Integration with local AI services
Community Server/Control Panel version 12.6.0.1900
Type of installation of Workspace deb/rpm installation on Ubuntu 20.04
Browser version: Chrome and Firefox
This is a feature request that would set ONLYOFFICE apart: Create OLLAMA / OpenWebUI integration, allowing access of AI models as collaborative users in all applications. While I understand the basic integration with OpenAI’s ChatGPT, those of us with in-house capabilities would love to use these with the privacy and security we have grown used to in ONLYOFFICE.
Hello @aharper
Do you mean this one? GitHub - open-webui/open-webui: User-friendly WebUI for LLMs (Formerly Ollama WebUI)
Please provide us with details of the suggestion. Do you want to integrate it into the editor interface (similar to how we did it for the ChatGPT) or do you have some other ideas for implementation?
Sorry for the long reply, but there is a lot to go over. We are a small private lab that uses Ollama on an in-house server with a semi-custom Large Language Model (LLM) as a generative AI in several roles. We use our own in-house AI for the same reason we use ONLYOFFICE; privacy and security. As you surmised, a large amount of our interaction with the AI uses Open-WebUI, but not all.
Our stack is Debian, Docker, Ollama, Open-WebUI, and ONLYOFFICE, located on two machines connected with a high speed backbone. The AI server with GPUs runs on one machine with a research library running on a Debian server attached to a rather large RAID array. When we renew our equipment, we will be looking at putting the entire stack and GPUs on a single machine and cloning it for high availability and failover. This will simplify deployment, reduce power consumption, and increase reliability.
Our specific uses, which I believe will not be unique in the future, uses local AI in several roles:
  1. Use a large language model to generate a comprehensive list of topics to write about, or to use as topics in a document outline.
  2. Generate the text of a document, then edit the document in order to both validate the AI generated material and put it in the author’s “voice”.
  3. Edit an existing document to raise or lower the vocabulary level to match the education of the anticipated reader.
  4. Translate a document form any language to any language that the LLM is capable of.
  5. Go through material from our library server (approx. 27TB of research data in various scientific disciplines) from text documents, pdfs, and LaTex to pictures and videos, looking for specific combinations of keywords, contexts, and tags, returning these as citations to go through for relevance including the properly formatted citation which may be directly pasted into the reference section of the paper. This more of a RAG than traditional LLM, but the interface is the same.
  6. Go through scientific journals and other academic information clearing houses looking for the same as the above. This application is more of a “web scrape”. Again, the interface is the same.
  7. Analyze large volumes of data from a database or spreadsheet to find specific patterns or correlations, doing so with a simple, clearly stated request, and outputting the results to a spreadsheet and/or document table as an example or appendix.
  8. Work through a development or problem with an interaction with a researcher using all the capabilities listed above, then output the findings in a standardized document template. Once this document is reviewed by the researcher, it is stored on the researcher’s private folder(s) and/or the shared library server mentioned above.
  9. Generate a glossary of terms, both those used in the document and terms used in the subject matter trade-space or domain. This helps build capability of the reader even when their experience and/or expertise in the subject matter is limited. We generally put this in as an appendix in jargon- and acronym-heavy documents, and our AI helps us identify these as well.
  10. Check the document against a list of internal secrets, classified, or embargoed data to properly classify the document, limiting access to personnel cleared for it, and recommending edits to obscure sensitive data prior to release in the form of publication, peer review, or press releases.
The result for us is that this automates a large amount of the repetitive tasks associated with scientific research documentation, and we have other forms of automation capable of doing much of the other repetitive work as well, reducing human error and some bias. We are capable of research that labs ten times our size and larger would take decades to perform, performing it better and in weeks or months.
The integration with ONLYOFFICE we would love to see is pretty much what we are currently doing manually, but obviously make it less scientific research specific:
  1. Direct connection to localhost or remote server Ollama based AI (port 11434) with a dialog box and the option to keep the data in the chat box to cut and paste it, or output it directly in the document you are working on.
  2. Show the AI as a collaborator in the document when you go into the versioning so that you can easily see changes. This would also be helpful if the AI is annotating the document as well.
  3. Full translation of a document, generating a new document as output with an extended file name indicating AI translation. In our case Erforschungsdokument.docx would produce Erforschungsdokument [AI_DE-EN].docx as the English translated document.
  4. Similarly, documents may be reworded to change the tone, length, and/or reading level with a change in the filename to indicate the modification. As an example, converting a PhD level paper to an American 12th grade reading level at 400 words would take PhD_document.docx and produce PhD_document [AI_PhD-12_400w].docx. This is incredibly useful in press releases.
  5. The ability to generate whole documents from output, either free form or following a template, placing them in a folder for human review, or flagging them in some other way (tag and/or watermark?).
  6. Generate a list of material from a body of data using online as well as local resources which match the query. In our case we use such a list to identify supporting as well as contradictory material.
  7. Generate a glossary of terms as a chapter or appendix as mentioned above.
  8. Where external material is used, help the author properly cite the sources, both using the inline forms as well as the standard reference formats (APA, MLA, Chicago, and Turabian), pasting these in the appropriate place in the document.
  9. Allow the AI to produce new tabs in a spreadsheet or generate entirely new spreadsheets to output requested data. Modifying existing sheets may also be done, but should only be allowed within specifically defined ranges to prevent inadvertent overwriting.
Much of this could be accomplished by creating a plugin that connects to the Ollama port on the server (127.0.0.1:11434 or 192.168.1.8:11434 as examples), then becomes a user on the OPENOFFICE system that the user can make requests from. The rest is largely template driven, which can be accomplished on the LLM side as we are doing now and/or within the ONLYOFFICE plugin.
Other applications of such a system include the automation of general clerical work, technical reports in various industries, and numerous others. While this addition to ONLYOFFICE would only eliminate a bit of cut and paste for us, it is a feature set that would completely set your office suite apart from the others once again.
integrators would be able to deploy turnkey solutions based on the stack of Ollama, Open-WebUI, and ONLYOFFICE. We were considering spinning off a company to do just that, even generating our own ONLYOFFICE plugin to do the things outlined here, but our board ultimately decided that this would be a distraction to what we already do. That said, we would be interested in helping others accomplish this.
Hello @aharper
Wow! Thank you for the provided details! The described idea of the local AI services (i.e., Ollama) integration sounds interesting. We need some time to discuss it internally. I will update this thread once we have something to share.
Glad to help. I’m sure there are other use cases and methodologies; those are only the ones we use. If we can help with some sort of implementation, just let us know. One specific use case I can give you is concept and product development.
We were working on a project using a phase change material in the back wall of greenhouses so that it can retain thermal energy, then release it slowly at night. This is nothing new, but we were going to use paraffin as the material, as it changes state from solid to liquid and back in the right temperature range, releasing a large amount of heat as is transitions from a liquid to a solid. Unfortunately this was a fire risk, and so this project was abandoned. This is why I can use it as an example.
In this particular case, which is fairly typical of our process, the researcher discussed the concept with the RAG, ensuring that the concepts were thoroughly covered. After this, the LLM was tasked with creating a report in using our standardized idea documentation template. This is where I would have liked the AI to output the document rather than the researcher cutting, pasting, and formatting it.
Once the document has been reviewed by the researcher (right now during the cut and paste, but this would ideally be a solitary task), the document is saved to PDF format and forwarded on for team review. I would have attached the PDF report on this particular project, but I do not have upload permission as a new user.
Thank you for the provided sample of the usage case. We are still discussing the request internally, and I have no news to share at the moment. I will keep you posted once we have something.
P.S. your forum level has been increased recently and you can attach files to your posts now.
Hello @aharper
We have added your suggestion of using local AI services to internal tracklist. We have started working on it. I will update this thread once we have something to share.
I know you implemented GPT4All for local AI, but is there a chance this can extend to Ollama? GPT4All seems to only work if you’re running it on a local desktop, while Ollama I am able to serve to my small dev network.
Hello @sininspira
We have released v.2.2.0 of the AI plugin for the editor a few days ago, and added Ollama support:
Unfortunately, we are still working on the detailed documentation and samples. I believe we will publish it in 1-2 weeks.
Whoa, what a timing, I was just testing this and I see the feature is exactly 20 min old :smiley:
I got this very vague error “internal error” when I entered my local (over the network) http://ip:11434 i know its working since a http request responds : “Ollama is running”
Any log I can consult ?
Sorry for the last post, I know its not really the correct space (after googling a bit more)
I found the problem. (using the debug tools)
By default it will try to get the models from http://localhost:11434 and when it fails it will not retry. Even if I set the correct http://ip:11434 .
For now since I’m on linux, I simply created a linux tunnel :
ssh -L 11434:$IP:11434 svenn@$IP -N
So then the localhost:11434 just forwards the same models, after that works, i can change away from localhost:11434 to $IP:11434 and kill the (temp) tunnel.
Thanks for this cool plugin !
We are glad that the issue has been resolved. Please feel free to contact us if you face any issues.
By the way, we’ve posted a short guide for Ollama: How to connect Ollama to ONLYOFFICE and use its AI models when working on documents
Having this same issue on Windows connecting to a remote ollama instance on LAN. I may try to do this with Putty as a temporary workaround.
Hello @sininspira and @svennd
We are checking the described situation with URL parameter for Ollama. I will update this thread once we have something to share.
Hi,
Having a problem accessing the remote ollama running in the local network, plus the local ollama doesn’t have API key to place in the AI settings box
please advise
thanks for the trick! my ollama remote instance work now.
Hello @fenris
We are still checking the described scenario in this thread regarding the usage of a custom URL for Ollama settings. I will update this thread as soon as possible.
We have released plugin v.2.2.2 and we added the possibility of using custom providers:
This should resolve the situation of using custom URL for Ollama, please check it out and let us know the result.
I have tried to use providerTempate. Updated URL, name, addon. But when I want to upload the provederTemplate I just end up with Error adding provider from file, try again.
Any suggestions?
Hello @schizza
What provider and AI model are you using? Could you please record a video file of your test?
