ONLYOFFICE Mobile: Documents / Projects / Web Editors
Device: Motorola G7
OS version: 11
App version: 5.5.2
Mode: Connect to Cloud / On Device
Browser version (for Web editors):
First off, I love the idea of a mobile version of Onlyoffice, I love Onlyoffice. However, the Google drive integration is broken (or maybe it’s more Google’s fault) but the connection times out and I have to log back in every time I need to save a document. I didn’t know this the first time and I had been working on a document and when I saved the file i got an error message and I was prompted to log back in to Google drive. Doing so then caused the doc on Google drive to reload and I lost all of my edits. This was very frustrating!!! Maybe it’s not possible with Onlyoffice, but man the way Google docs works seamlessly between devices is hard to leave behind. But you guys do endnotes. None of the writing I do makes foot notes remotely reasonable. also, are you guys planning to update your mobile app anytime soon?
Hello @keweminer
Apologize for the delayed response and would like to request that you provide us with a detailed scenario regarding Google Drive, if possible, along with a screen recording. Additionally, we are planning to release an updated version of ONLYOFFICE Mobile Editors
this week, but timeframes can change.
Thank you for your patience and understanding.
i update the topic because I have the same problem, indeed i wrote to the support and they tell me it can’t be fixed because is google fault, I want to check if anyone can confirm
Hello @gennodi
Unfortunately, this is correct. Currently Documents app cannot connect to the Google service due to a limitation on the Google side.
Came here for this topic - I’m right in understanding that currently (Google said OnlyOffice was requesting secure data or something). So OnlyOffice and Google Drive don’t work together at all?
Not being able to work with Google Drive is a dealbreaker for me, unfortunately.
Hello @Unmindful
It is not quire right - Documents app does not request any secure data, Google has changed their polices and, unfortunately, it affects Documents app in a way that it cannot connect to Google Drive. We are processing the situation, but, unfortunately, I cannot provide any ETA for the solution at the moment.
Sorry for the inconvenience.
That’s a shame as it’s a dealbreaker for me. The various online/open source apps are all usable for my purposes. The complications for me are all about not copying files between cloud services (G Drive/OneDrive/OnlyOffice/iCloud etc) to support version control, while being able to work on a Chromebook with occasional forays into iOS/Mac OS.
Ah well. The search continues.
