Document Server version:
OS:
Browser version:
I would like to integrate only office into my management system. But if I create a .doc file and try to print it from my windows management system I get the response that there is no app that reads those files even though I have entered that .doc files must be read by only office.
I would like some advice and help.
I use the shellexecute function to read the file (classic example test.doc).
thanks
Hello @Francesco.daquila
Sorry for the late reply.
Could you shed some light on the usage scenario that you are trying to achieve? Correct me if I’m wrong but it seems that you are trying to print the file by directly right-clicking it and tapping Print, is that so? Also, provide us an example of the shellexecute function that you use.
Do I understand you right that you are using Desktop Editors?
