Logs from the mail container:
docker logs onlyoffice-mail-server
[ INFO ] Checking configuration file: /usr/src/iRedMail/config ... [FOUND]
[ INFO ] Import installation process status from file: /usr/src/iRedMail/runtime/install.status.
Waiting for external MySql response
And elasticsearch (truncated due to Discourse post length limits):
docker logs onlyoffice-elasticsearch
{"type": "server", "timestamp": "2024-01-25T10:55:23,452Z", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "version[7.16.3], pid[8], build[default/docker/4e6e4eab2297e949ec994e688dad46290d018022/2022-01-06T23:43:02.825887787Z], OS[Linux/6.1.0-17-amd64/amd64], JVM[Eclipse Adoptium/OpenJDK 64-Bit Server VM/17.0.1/17.0.1+12]" }
{"type": "server", "timestamp": "2024-01-25T10:55:23,611Z", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "JVM home [/usr/share/elasticsearch/jdk], using bundled JDK [true]" }
{"type": "server", "timestamp": "2024-01-25T10:55:23,618Z", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "JVM arguments [-Xshare:auto, -Des.networkaddress.cache.ttl=60, -Des.networkaddress.cache.negative.ttl=10, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -XX:-OmitStackTraceInFastThrow, -XX:+ShowCodeDetailsInExceptionMessages, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dio.netty.allocator.numDirectArenas=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Dlog4j2.formatMsgNoLookups=true, -Djava.locale.providers=SPI,COMPAT, --add-opens=java.base/java.io=ALL-UNNAMED, -XX:+UseG1GC, -Djava.io.tmpdir=/tmp/elasticsearch-3255087994172811187, -XX:+HeapDumpOnOutOfMemoryError, -XX:+ExitOnOutOfMemoryError, -XX:HeapDumpPath=data, -XX:ErrorFile=logs/hs_err_pid%p.log, -Xlog:gc*,gc+age=trace,safepoint:file=logs/gc.log:utctime,pid,tags:filecount=32,filesize=64m, -Des.cgroups.hierarchy.override=/, -Xms1g, -Xmx1g, -Dlog4j2.formatMsgNoLookups=true, -XX:MaxDirectMemorySize=536870912, -XX:G1HeapRegionSize=4m, -XX:InitiatingHeapOccupancyPercent=30, -XX:G1ReservePercent=15, -Des.path.home=/usr/share/elasticsearch, -Des.path.conf=/usr/share/elasticsearch/config, -Des.distribution.flavor=default, -Des.distribution.type=docker, -Des.bundled_jdk=true]" }
{"type": "server", "timestamp": "2024-01-25T10:57:03,770Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [aggs-matrix-stats]" }
{"type": "server", "timestamp": "2024-01-25T10:57:03,796Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [analysis-common]" }
{"type": "server", "timestamp": "2024-01-25T10:57:03,833Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [constant-keyword]" }
{"type": "server", "timestamp": "2024-01-25T10:57:03,883Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [frozen-indices]" }
{"type": "server", "timestamp": "2024-01-25T10:57:03,892Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [ingest-common]" }
{"type": "server", "timestamp": "2024-01-25T10:57:03,928Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [ingest-geoip]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,008Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [ingest-user-agent]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,063Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [kibana]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,064Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [lang-expression]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,065Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [lang-mustache]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,066Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [lang-painless]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,081Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [legacy-geo]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,098Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [mapper-extras]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,120Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [mapper-version]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,131Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [parent-join]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,140Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [percolator]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,164Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [rank-eval]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,165Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [reindex]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,167Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [repositories-metering-api]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,169Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [repository-encrypted]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,171Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [repository-url]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,181Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [runtime-fields-common]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,192Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [search-business-rules]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,214Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [searchable-snapshots]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,216Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [snapshot-repo-test-kit]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,224Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [spatial]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,228Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [transform]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,258Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [transport-netty4]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,259Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [unsigned-long]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,264Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [vector-tile]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,300Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [vectors]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,306Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [wildcard]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,308Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-aggregate-metric]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,320Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-analytics]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,325Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-async]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,336Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-async-search]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,392Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-autoscaling]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,400Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-ccr]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,415Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-core]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,427Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-data-streams]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,456Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-deprecation]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,469Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-enrich]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,524Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-eql]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,536Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-fleet]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,541Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-graph]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,547Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-identity-provider]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,599Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-ilm]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,637Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-logstash]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,643Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-ml]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,652Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-monitoring]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,700Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-ql]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,737Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-rollup]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,751Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-security]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,796Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-shutdown]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,808Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-sql]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,817Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-stack]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,862Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-text-structure]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,870Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-voting-only-node]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,872Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-watcher]" }
{"type": "server", "timestamp": "2024-01-25T10:57:04,890Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded plugin [ingest-attachment]" }
{"type": "server", "timestamp": "2024-01-25T10:57:07,119Z", "level": "INFO", "component": "o.e.e.NodeEnvironment", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "using [1] data paths, mounts [[/usr/share/elasticsearch/data (/dev/xvda2)]], net usable_space [164.7gb], net total_space [189.8gb], types [ext4]" }
{"type": "server", "timestamp": "2024-01-25T10:57:07,174Z", "level": "INFO", "component": "o.e.e.NodeEnvironment", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "heap size [1gb], compressed ordinary object pointers [true]" }
{"type": "server", "timestamp": "2024-01-25T10:57:08,364Z", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "node name [4eedebd64be9], node ID [WH69_b6YT76pdtkqgp2T5Q], cluster name [docker-cluster], roles [transform, data_frozen, master, remote_cluster_client, data, ml, data_content, data_hot, data_warm, data_cold, ingest]" }
{"type": "server", "timestamp": "2024-01-25T11:01:15,417Z", "level": "ERROR", "component": "o.e.b.ElasticsearchUncaughtExceptionHandler", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "uncaught exception in thread [main]",
"stacktrace": ["org.elasticsearch.bootstrap.StartupException: ElasticsearchException[Failure running machine learning native code. This could be due to running on an unsupported OS or distribution, missing OS libraries, or a problem with the temp directory. To bypass this problem by running Elasticsearch without machine learning functionality set [xpack.ml.enabled: false].]",
"at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:170) ~[elasticsearch-7.16.3.jar:7.16.3]",
"at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:157) ~[elasticsearch-7.16.3.jar:7.16.3]",
"at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:77) ~[elasticsearch-7.16.3.jar:7.16.3]",
"at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:112) ~[elasticsearch-cli-7.16.3.jar:7.16.3]",
"at org.elasticsearch.cli.Command.main(Command.java:77) ~[elasticsearch-cli-7.16.3.jar:7.16.3]",
"at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:122) ~[elasticsearch-7.16.3.jar:7.16.3]",
"at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:80) ~[elasticsearch-7.16.3.jar:7.16.3]",
"Caused by: org.elasticsearch.ElasticsearchException: Failure running machine learning native code. This could be due to running on an unsupported OS or distribution, missing OS libraries, or a problem with the temp directory. To bypass this problem by running Elasticsearch without machine learning functionality set [xpack.ml.enabled: false].",
"at org.elasticsearch.xpack.ml.MachineLearning.createComponents(MachineLearning.java:845) ~[?:?]",
"at org.elasticsearch.node.Node.lambda$new$18(Node.java:733) ~[elasticsearch-7.16.3.jar:7.16.3]",
"at java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:273) ~[?:?]",
"at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1625) ~[?:?]",
"at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509) ~[?:?]",
"at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499) ~[?:?]",
"at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:921) ~[?:?]",
"at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]",
"at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:682) ~[?:?]",
"at org.elasticsearch.node.Node.<init>(Node.java:747) ~[elasticsearch-7.16.3.jar:7.16.3]",
"at org.elasticsearch.node.Node.<init>(Node.java:309) ~[elasticsearch-7.16.3.jar:7.16.3]",
"at org.elasticsearch.bootstrap.Bootstrap$5.<init>(Bootstrap.java:234) ~[elasticsearch-7.16.3.jar:7.16.3]",
"at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:234) ~[elasticsearch-7.16.3.jar:7.16.3]",
"at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:434) ~[elasticsearch-7.16.3.jar:7.16.3]",
"at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:166) ~[elasticsearch-7.16.3.jar:7.16.3]",
"... 6 more"] }
{"type": "server", "timestamp": "2024-01-25T11:03:02,231Z", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "version[7.16.3], pid[7], build[default/docker/4e6e4eab2297e949ec994e688dad46290d018022/2022-01-06T23:43:02.825887787Z], OS[Linux/6.1.0-17-amd64/amd64], JVM[Eclipse Adoptium/OpenJDK 64-Bit Server VM/17.0.1/17.0.1+12]" }
{"type": "server", "timestamp": "2024-01-25T11:03:02,324Z", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "JVM home [/usr/share/elasticsearch/jdk], using bundled JDK [true]" }
{"type": "server", "timestamp": "2024-01-25T11:03:02,329Z", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "JVM arguments [-Xshare:auto, -Des.networkaddress.cache.ttl=60, -Des.networkaddress.cache.negative.ttl=10, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -XX:-OmitStackTraceInFastThrow, -XX:+ShowCodeDetailsInExceptionMessages, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dio.netty.allocator.numDirectArenas=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Dlog4j2.formatMsgNoLookups=true, -Djava.locale.providers=SPI,COMPAT, --add-opens=java.base/java.io=ALL-UNNAMED, -XX:+UseG1GC, -Djava.io.tmpdir=/tmp/elasticsearch-11905759924447039891, -XX:+HeapDumpOnOutOfMemoryError, -XX:+ExitOnOutOfMemoryError, -XX:HeapDumpPath=data, -XX:ErrorFile=logs/hs_err_pid%p.log, -Xlog:gc*,gc+age=trace,safepoint:file=logs/gc.log:utctime,pid,tags:filecount=32,filesize=64m, -Des.cgroups.hierarchy.override=/, -Xms1g, -Xmx1g, -Dlog4j2.formatMsgNoLookups=true, -XX:MaxDirectMemorySize=536870912, -XX:G1HeapRegionSize=4m, -XX:InitiatingHeapOccupancyPercent=30, -XX:G1ReservePercent=15, -Des.path.home=/usr/share/elasticsearch, -Des.path.conf=/usr/share/elasticsearch/config, -Des.distribution.flavor=default, -Des.distribution.type=docker, -Des.bundled_jdk=true]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,939Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [aggs-matrix-stats]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,952Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [analysis-common]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,953Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [constant-keyword]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,955Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [frozen-indices]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,956Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [ingest-common]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,969Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [ingest-geoip]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,984Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [ingest-user-agent]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,985Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [kibana]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,986Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [lang-expression]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,987Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [lang-mustache]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,987Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [lang-painless]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,988Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [legacy-geo]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,996Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [mapper-extras]" }
{"type": "server", "timestamp": "2024-01-25T11:03:42,998Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [mapper-version]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,000Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [parent-join]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,004Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [percolator]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,006Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [rank-eval]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,006Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [reindex]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,008Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [repositories-metering-api]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,016Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [repository-encrypted]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,020Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [repository-url]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,022Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [runtime-fields-common]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,023Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [search-business-rules]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,028Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [searchable-snapshots]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,029Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [snapshot-repo-test-kit]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,030Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [spatial]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,040Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [transform]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,045Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [transport-netty4]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,046Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [unsigned-long]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,047Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [vector-tile]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,047Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [vectors]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,048Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [wildcard]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,049Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-aggregate-metric]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,052Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-analytics]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,053Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-async]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,054Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-async-search]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,056Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-autoscaling]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,058Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-ccr]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,064Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-core]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,065Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-data-streams]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,067Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-deprecation]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,070Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-enrich]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,072Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-eql]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,080Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-fleet]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,084Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-graph]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,085Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-identity-provider]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,086Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-ilm]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,087Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-logstash]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,088Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-ml]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,092Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-monitoring]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,093Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-ql]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,102Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-rollup]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,103Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-security]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,108Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-shutdown]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,109Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-sql]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,110Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-stack]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,111Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-text-structure]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,112Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-voting-only-node]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,120Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded module [x-pack-watcher]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,122Z", "level": "INFO", "component": "o.e.p.PluginsService", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "loaded plugin [ingest-attachment]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,566Z", "level": "INFO", "component": "o.e.e.NodeEnvironment", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "using [1] data paths, mounts [[/usr/share/elasticsearch/data (/dev/xvda2)]], net usable_space [164.7gb], net total_space [189.8gb], types [ext4]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,575Z", "level": "INFO", "component": "o.e.e.NodeEnvironment", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "heap size [1gb], compressed ordinary object pointers [true]" }
{"type": "server", "timestamp": "2024-01-25T11:03:43,782Z", "level": "INFO", "component": "o.e.n.Node", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "node name [4eedebd64be9], node ID [HYRExBhaRVKZHvrFKABPlg], cluster name [docker-cluster], roles [transform, data_frozen, master, remote_cluster_client, data, ml, data_content, data_hot, data_warm, data_cold, ingest]" }
{"type": "server", "timestamp": "2024-01-25T11:05:04,651Z", "level": "ERROR", "component": "o.e.b.ElasticsearchUncaughtExceptionHandler", "cluster.name": "docker-cluster", "node.name": "4eedebd64be9", "message": "uncaught exception in thread [main]",
"... 6 more"] }
