ERROR: for onlyoffice-proxy Cannot start service onlyoffice-proxy: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error mounting “/app/onlyoffice/config/nginx/templates/nginx.conf.template” to rootfs at “/etc/nginx/nginx.conf”: mount /app/onlyoffice/config/nginx/templates/nginx.conf.template:/etc/nginx/nginx.conf (via /proc/self/fd/6), flags: 0x5000: not a directory: unknown: Are you trying to mount a directory onto a file (or vice-versa)? Check if the specified host path exists and is the expected type
iam facing above error while installing docspace into my localhost. can any one help me on this
the steps which i followed is
wget http://download.onlyoffice.com/docspace/docspace-install.sh
bash docspace-install.sh -ep 82
