I took the MSI that I put in the GPO and I did a gpupdate on the PC but nothing happens, however when I go to the server on the msi package in the advanced options and I check ignore language when deploying it works but it installs the software in a language I don’t know…
Do you have any solutions?
Thanks
OS version: Windows 11
App version: 7.5
On the clients and servers we have the French language (France).
The program doesn’t install via the GPO, I have to check ignore languages on installation in the advanced settings, but it’s in a language I don’t understand.
However, if I install the MSI manually it works and is in French.
@Nikolas
I have the same problem. Please change the default language of the MSI file from Czech to English, thank you. Now only the publisher can do that so I am waiting for the fix.
I understand your frustration.
Unfortunately, I can only provide updates on the current status of the bug.
I’m sorry to say that we won’t be able to fix this bug by version 8.1.0.
More than a year later, the problem still hasn’t been fixed…
It’s really sad for an alternative to O365, because it’s not easy to deploy in the enterprise.
We’ve received information that this bug has been fixed and the installation should now proceed correctly.
Could you please confirm whether the issue still persists on your side?
