log info:
[2022-10-12T09:48:37.210] [WARN] nodeJS - Express server starting…
[2022-10-12T09:48:37.212] [WARN] nodeJS - Set services.CoAuthoring.token.enable.browser, services.CoAuthoring.token.enable.request.inbox, services.CoAuthoring.token.enable.request.outbox in the Document Server config to prevent an unauthorized access to your documents and the substitution of important parameters in ONLYOFFICE Document Server requests.
[2022-10-12T09:48:37.213] [WARN] nodeJS - Failed to subscribe to plugin folder updates. When changing the list of plugins, you must restart the server. File system | Node.js v23.7.0 Documentation
[2022-10-12T09:48:37.445] [WARN] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 7.1.1. Build: 23
[2022-10-12T10:12:32.796] [WARN] nodeJS - Express server starting…
[2022-10-12T10:12:32.797] [WARN] nodeJS - Set services.CoAuthoring.token.enable.browser, services.CoAuthoring.token.enable.request.inbox, services.CoAuthoring.token.enable.request.outbox in the Document Server config to prevent an unauthorized access to your documents and the substitution of important parameters in ONLYOFFICE Document Server requests.
[2022-10-12T10:12:32.798] [WARN] nodeJS - Failed to subscribe to plugin folder updates. When changing the list of plugins, you must restart the server. File system | Node.js v23.7.0 Documentation
[2022-10-12T10:12:33.024] [WARN] nodeJS - Express server listening on port 8000 in production-linux mode. Version: 7.1.1. Build: 23
[2022-10-13T03:07:55.611] [WARN] nodeJS - error description: docId = undefined errorId = Server shutdow
