Inserting Values from one Workbook into another (Spreadsheet)
Hi There,
i have a very simple question but “googling” and looking around via the search function in the forum didn’t get me the solution… So here it comes:
I am Using OnlyOffice Desktop on Mac 8.0.3 and using Spreadsheets. When i copy values from one Workbook with formulas into another Workbook without formulas i want to insert “only values” as i am used in Excel. When i copy in Excel i can insert in the next workbook and Choose insert → only Values.
How do i do this in OnlyOffice? I was trying but didn’t find the solution and cannot believe that it is not possible.
Thanks in advance!!
Sorry Version of OnlyOffice is 8.3.2
Hello there,
you paste the copied cells [CTRL+V] and you should see a small box appearing, which you can expand by clicking on the down-arrow and there you have all the other options including “copy only values”.
Thank you very much - that works!
