Is there an API that allows inserting HTML into the document I’m opening with ONLYOFFICE Document Editor?
Hello @sxiawna
Plugin method PasteHtml allows you to paste the text in HTML format into the document. This method is also used in ready-to-go plugin Get and paste html:
Try copy-pasting it into the editor.
