Unfortunately not… Via the reference tab/cross reference, there is no opportunity to insert the filename (for example), or the date, or the page number… (May be it is possible, but I cannot find how…)
I need this feature too, particularly the TITLE field.
I have a lot of existing documents that use this field to automatically display the title of the document in places like beginning of the first page, header and footer, etc.
If I change the Title in the Document Info screen, and try to update the field, I get the error “Error! Reference source not found.”
