There is a way to insert a table with docBuilder and later replace the contentin the cells?
Hello, do you need to insert a table into Document or Spreadsheet file?
i need to insert a table into document
Here are the methods for creating and manipulating Table Elements for Document Editor: ONLYOFFICE Api Documentation - ApiTable
ONLYOFFICE Api Documentation - ApiTableCell
ONLYOFFICE Api Documentation - ApiTableRow
For example, this method allows to add a table with specified number of cells and to add content to the cells: ONLYOFFICE Api Documentation - AddElement
This method allows to search for a certain text within the cells and do manipulations with it: ONLYOFFICE Api Documentation - Search
Also, pay attention to the following method of searching and replacing: ONLYOFFICE Api Documentation - SearchAndReplace
