Insert a link
OS version: windows 11
App version: 8.1.0.169
The problem with stretching the links in the table is if you insert one row or cell and then stretch it. then the changes will not be saved. and then we will be 0 all the time. I recorded a video. about the problem. and also attached additional files.
https://drive.google.com/drive/folders/1TT8NMHui0iPFlWTMlD36LtsvqRyAUbWU?usp=sharing
Hello, thank you for the provided info, we are currently analyzing the issue
Hello, we have reproduced the above-mentioned issue and registered relevant bug in our bug tracking system, we will be working on it
