Thank you very much for developing this office software, it’s really helpful. It would be great if you also could add an automatic indentation in bullet lists (and numbered lists, etc) not just on the first line, but also maintain the same indentation throughout the entire paragraph. It will look better and it will save me lots of time that I otherwise would have to spend on adding the indentation manually.
Thanks
Hello!
When you create lists indentation is the same for all the lines. In our Help Center you can read more about creating lists.
Could you please send us a screenshot representing the issue?
