“Indent” adds characters as units of measurement 。thanks
Hello! Thank you for your feedback. May I know what is the expected operation way for you here?
ok.look this example.it is msoffice.thanks
Hello @letgooo
If you don’t mind, I will step to this thread too.
It isn’t clear what you want to achieve. Please clarify step-by-step what your suggestion is. Do you want to add some new parameters to Measurement (File > Advanced settings > Unit of measurement)?
for example:
Now I got it, thank you! We are discussing the suggestion internally. I will update this thread once we have something to share.
Hello @letgooo
We have added your suggestion to internal tracksystem. We have started working on it.
Thank you for your idea!
