Need dedicated support? Click here
Click here
Incorrect saving from XLSX to PDF (builder.SaveFile as PDF)
Report a bug:
In documentbuilder version 7.4.0.166, the following problem has appeared: when changing the size of columns and rows in xlsx, saving to pdf does not work correctly.
For example, next code:
builder.SetTmpFolder("./Temp");
builder.OpenFile("Test.xlsx");
var oSheet = Api.GetActiveSheet();
oSheet.GetRange("B1").SetColumnWidth(20);
oSheet.GetRange("A2").SetRowHeight(50);
oSheet.GetRange("A4").SetRowHeight(0);
builder.SaveFile("xlsx", "./Test_result.xlsx");
builder.SaveFile("pdf","./Test_result.pdf");
builder.CloseFile();
As a result, we will get the correct new xlsx file (Test_result.xlsx ), but in the pdf file (Test_result.pdf), the sizes of columns and rows will not be changed
In documentbuilder version 7.2.0.204, this worked correctly
I uploaded archives with examples of results for different versions to disk:
https://drive.google.com/drive/folders/1oZjeIArL1WMGd-YZ20apBMtTUKDltRCf?usp=sharing
DocumentBuilder version: 7.4.0.166
ps: in the desktop editor (“ONLYOFFICE Desktop Editors version 7.4.0.163”) everything is saved in pdf correctly
Hello @Alex2022
thank you for detailed description, we are checking the situation.
