Impossible to access control panel
For feature suggestions, describe the result you would like to achieve in detail:
Community Server/Control Panel version:
Type of installation of Workspace (docker, deb/rpm, exe)
OS:
Browser version:
From the beginning i’ve installed Onlyoffice Community server (install on windows serveur 2016) i’ve a problem to access control panel.
In fact, i can’t use the https automatic option to pass onlyoffice in https.
So i’ve use lets encrypt to do it…
Unfortunately since this date, i can’t acces control panel and i don’t know why!
If someone have an idea it will be wonderful! :slight_smile:
Thats all
Thx for your help
Hello Martin,
Could you please specify the guide you were using to enable HTTPS for your Workspace installation?
Hi,
Sorry for late answer, i have just used Lets encrypt and install a security certificate for the “website” Onlyoffice and force the HTTPS. That’s all.
I don’t know what i can say moreover
Thx
Have you used our script for certificate generation or have you just ran certbot which automatically generated and applied the certificate?
No i have download lets encrypt and install on my server (its a VM windows server 2016 standard).
Then i 've just launch and certificate it… dont use your script because it doesnt work :frowning:
Hi,
Anyone have an answer or anything ? :slight_smile:
Thx
Hi, sorry for the late reply. The correct procedure to enable HTTPS for Workspace on Windows is described here:
https://helpcenter.onlyoffice.com/installation/groups-https-windows.aspx
In your case I’m afraid Let’s Encrypt utility could alter the configs in an unwanted way. I would recommend reinstalling the Workspace and after that enable HTTPS as described in the documentation.
Ok thanks you ! If i want to reinstall everything, how can i save my data (and more than that, where are they ? :slight_smile:
Portal files are stored at CommunityServer\Data\ directory. The better option is to create a snapshot of the server before reinstallation, so you are able to quickly roll back to the working state.
