Impossible to access another disk
OS version: Ubuntu24
App version: 8.1.1.27 (snap)
Downloaded from: ONLYOFFICE website / Other (specify). Please point us to the installation guide that you used as well.
Additional information:
Any relevant details about the situation. You can also attach images and videofile to the post (or to place them to external storage).
I cannot open any folder (containing documents) which is located on another disk on my laptop (/data) which is accessible by LibreOffice anyway…
Installed onlyoffice from the command line:
$ sudo snap install onlyoffice-desktopeditors
Hello @steven777
As far as I know, snap by default works with files from /home directory only. For other disks it must be configured with removable-media interface, but it is up to you.
Alternative solution in this case is to install Desktop Editors from other sources, e.g. from a DEB/RPM package. The list of all available installation types for Desktop Editors is available here:
